2G 96 GST whats next?
1998_gst
77
Oct 19, 2011
Melrose, Minnesota
hey everyone, just looking for some advice. I have a 96 gst with a rebuilt 98 7bolt. mods done are evo 3, full straight 3 inch, hallman proRX MBC, balance shaft removed, greddy FMIC, afc neo, AFX wideband, intake, aeromotive afpr 220 walboro, FIC 850 injectors, ACT 2100 clutch, don't think i'm forgetting anything. my question is whats next? haha my goals are just a fast street car that i can take to the strip every now and then. let me know if i'm missing anything as far as supporting mods? i've only put 20 miles at factory boost on the car with the current set up. thanks
Everyone is going to say ECMLink and make sure you've done all necessary tune up work. Then, they will say enjoy your 16g and upgrade to a Holset or bigger turbo.
Assuming he rebuilt or got the engine rebuilt, looks like most maintenance is done.
But the guy needs an actual tune, instead of tricking the ecu, with larger injectors than the safc can handle with current mods..
Ok well assuming the maintenence is done.The link in my first post is what I would invest in next.Then put in the larger injectors and add a couple psi.
Also aftermarket boost gauge is a must, factory one is crap.
Ehh you can get a oil pressure gauge if you want.It definatly will tell you what pressure the oil is at.May come in handy but, not the most nessesary thing.
I like a volt gauge but also not nessesary.
You have the wideband so do you have the wideband gauge?
The exhaust, is it 2.5 o2 housing and 3 inch all the way back?
Is the turbo ported or no?
Good tires are always a very good plus.
Coilovers always a good idea too.
I see $ signs but, you got to pay to play.
you could use a turbo timer as well. just wondering how are you breaking in your engine? i have rebuilt 1994 4g63 that i just dropped into my 1997 gst and ive heard numerous ways to break them in LOL
