96 eclipse gs 2.0 using 95 talon ecu, wire harness , fuel rail, fuel injectors
killermind
Aug 21, 2012
Hatillo, Puerto Rico
So here I am again, my car has a erratic idle because there's too much fuel pressure on the fuel rail and the injectors, I was using the talon injectors and changed them back to the eclipse ones, I found out that on idle speed the talon is at a lower level of fuel pressure than the eclipse. that info came from alldata, is here a way to control that fuel pressure, Im using the talon fuel pump too, but its not connected to the relay so its sending fuel at all times, but I read that the relay will send fuel as long it detects movement fro the cam, wich means that as long as the car is on it will send fuel, so I dont think that the fuel pump is the issue, also I installed a fuel return line to the fuel tank because I'm using the talon fuel rail and it has a return line on it( If I'm not using the correct term sorry, my english its not si good XD) please help , I want my dsm back XD, thanks again in advance for all your help over these years
