eclipse 97 2.0 ecu on eclipse 96
killermind
Aug 21, 2012
Hatillo, Puerto Rico
Can I replace the ecu, wire harness and sensors of a eclipse 97 to a eclipse 96 both are dohc 2.0? or do I have to do a engine swap? thanks in advance
Yes, you can. You leave the crank sensor the way it is. Since all the 2g models use crank sensor. Open the valve cover of the 96 and check if theres a place to bolt the 97 sensor. If there is, then your good to go. If not, then you will have to stick with the cam sensor. Which is not hard to do, just change the 97 clip (black clip for cas on left side) to a 96 clip (on the right side if you are looking at the motor). If you do not mind me asking why do you want to change all this?
Good luck and let us know how it goes
my car wont turn since last year and im desperate to have it running up again, its a electrical problem and nobody has been able to fix it, and I buying another eclipse at a good price up and running, the thing is that the paint is all messed up on the one im buying and I want to use my car body anyways : )
Good idea, that way you take anything else you need and sell it parts. That way you get your money back and your car running again :)
Well good luck and let us know how it goes. We are more than happy to help you brother.
thanks , i'll keep you guys informed : )
another question, can I change the wire harness without getting the engine out? thanks again
Yes, you can takes around 30 mins to do it. Start unpluging the clips from inside. Then, start on the under hood harness. Unplug everything and pull the harness from outside of the car. The engine harness divides to two sets, one on the firewall for the selinoids and the other for injectors, coil pack, tb sensors, speed sensor, etc you get the point. When you put the new harness, make sure you DON'T forget the ground from inside if the car and same to the ground on the firewall.
Good luck
so I missed my chance to buy a eclipse 97 but today Im going to buy a eagle talon 95, can I use the wire harness and the ecu on my eclipse 96? thanks again
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
