95GSX-6Bolt-99ECU help
willtmcgee
38
Aug 24, 2011
Houston, Texas
I need to know what I need to for correct firing, Ive searched and found some say to swap the injectors, some swap the plug wires but all of them are using the 95 cas from what I could find
Mine is a complete 6 bolt swap with green top 1g CAS, with magnus CAS signal cable
I have two ECU's 95 with dsmlink 2 and a 99 ecu with ceddy, I would rather use the ceddy because my buddy uses it and is going to help me learn it. Any Opinions?
With a 99 car, 99 ecu, 6-bolt cas I always swapped the spark plug wires and never had any problems.
What wires need to be swapped with a 95 harness ( its a 95 Gsx) with 99 ecu and mag us cars cable
Hey bud if you have your ecu 95 chiped. with dsm link. just use that one . and hit the check box that says invert CAS signal, on your dsm link software. its the same as swicthing the plugs , if not just change the spark plug firing order hears a link to that picture. http://www.dsmtuners.com/forums/newbie-forum/393864-95-firing-order.html
this thread should help clear some confusion up. good luck man and stay strong Dont let Thieving Shops get you Adapt And Over come !:thumb:
cant answer that. your much better of running with a 95 eprom ecu. like the link
above shows in a picture. as for your 99 ecu. i don't see the firing order being
swapped but i really don't know. I am not familiar with that other option you have.
also . i understand your interest in using the 99 ecu because your friend has one, But
theirs more common knowledge when it comes to a 95 with dsm link, you'll have a
higher likely hood of meeting people with experience tuning on dsm link...
