95 tsi fwd o2 sensor wires shorted need help
eclitz88
59
Jul 2, 2012
Dixon, Illinois
Let's see what you guys think about this.
My buddy has a 95 tsi fwd
The PO did a hell of a hack job on the o2 sensor wires (sensor side), and all the wires shorted together, witch caused the sensor ground trace to short out. I personally replaced the front o2 sensor with a good used one from my car (after I installed wide band, had extra one). Then I fixed the trace in the ecu.
The car now starts and stays running and is drivable, but when you go to get on it, it cuts out. We are at a stump in the road with this.
Where should we start looking? Thanks again!
Alright it has a tdo5 Turbo, I want to say that it is a16g
fmic
WheaponR intake
Apexi prospecB boost controller (maybe it got reset'd, his battery was dead a couple times this week from not driving it.)
No power steering
Has a/c
Full exhaust
FP manifold
And it only has a narrow band witch is useless ( but he says it quit working the other day)
Im going to run the codes next time I see him.
Its like the coils aren't up to par, kind of cut out. It never has had this problem befor. and if I'm not mistaken it is when he trys to boost it. I know there is allot of possibilities to this but I'm thinking that it is an electrical issue.
Ill get more details from him tomorrow. I wish he would just join the forum and make life easier.
I don't think a front o2 sensor would cause your issue with my car before i welded a new bung in my down pipe for my wide band i ran my car with no o2 sensors and yes it would go in and out of closed loop at will and cause me to run really rich at 55mph like 11.1 rich BUT i had no other issues car still ran fine.
Resolved. Ground trace in the ecu shorted. Fixed the ground trace, but there was still problems. He ended up just changing out the ecu. Thanks everyone for your advice...
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
