95 talon tsi fwd first build
dosntknow
41
Feb 12, 2011
Richland, Mississippi
Hi everyone, here is my build. How the car is going to sit once this build is done.
ENGINE-
Solid motor mounts
Full wire tuck/delete
Fuse box relocation
Shaved Bay
Radiator moved 2" forward
Meth Injection kit
BLOCK-
Machined to spec
Manley rods
Wiesco 9.0:1 1mm overbore pistons
Cut stock crank
Oil squirters blocked with set screw
Forward facing OFH
Oil cooler delete
HEAD-
Kiggly HLA
Kiggly springs
SS Swirl polished 1mm oversized valves
Oil Port Mod 1&2
Forced Induction-
Garret T3/T4 .50 trim turbo
Cast iron manifold
38mm External wastegate w/dump tube
FMIC
3" GM MAF(At first then SD)
1g BOV
Suspension/Steering-
Depowered steering rack
Takico struts and springs
Tuning-
ECMlink V3 Full
Interior-
Delete rear seats
Front racing seats
Airbag delete (both) w/sensors and control unit
New carpet
Removal of anything not used
Body-
Galant Super VR4 front clip conversion
Here are some pics of when I got the car back in 2011.
After getting the veh i did several things.
body kit/ rims, AEM wideband
T3/T4 upgrade with Fuel mods 950cc injectors, fuel lab AFPR, and PR FMIC.
DSMlink v3 light for tuning, and oil filter relocation.
Also during times when money was a little tight did random body mods.
sorry about the bad image phone camera was scratched to hell and back.
About 8 months ago I had a spun rod bearing so it was time to start a full rebuild. Things that are going to happen while down are change internals to 9.0:1 compression pistons, forged rods, angled valve job, engine bay painted, wire tuck, fusebox relocate, replace interior, racing seats, lighter hood/fenders/doors, remove air bags, new steering wheel, solid motor mounts, upgrade fuel pump, big brake kit, rebuild trany, and alot more i may decide to do along the way.
after she was towed home,
video 1
[ame=http://www.youtube.com/watch?v=1Pr9jnJgIiE&feature=player_detailpage&list=UU0vh8cBCJsJ9HFpP6zc1qXQ]YouTube[/ame]
vid 2
[ame=http://www.youtube.com/watch?v=JSZTsbLYhFw&feature=player_detailpage]YouTube[/ame]
pulling motor and engine bay before pics
The interior before I gutted it
De-powered the steering rack. Following the miata mod for steering conversion. For any who want to do here is a link Flyin' Miata : Tech: 1.8 conversion
Took it apart getting ready to cut the seal off.
Here is the seal.
Re-assembled and packed with greese. All I have to do now is re-install.
wire harness out!
Did some work to the engine bay, here are some pics
before
primed
after
Got rods in today!
I have more pictures but i have reached my limit. Will post again with more later.
New parts are in here is a few pics.
Tank to rail fuel line and high flow filter.
Block back from machine shop.
New SS swirl polished valves, Kiggly HLA and Springs
Pistons are in! And assymbled!
