2G 95 gst won't start
Tim Smith
May 8, 2016
Ocala, Florida
Okay recently bought a 95 eclipse gst. I believe everything is stock besides a huge aftermarket intercooler. Ran the car for Prolly a total of 20 mins off an on attempting to load onto a trailer and what not. Hard to start and ran very rough. Got it home and the timing belt fell off trying to start it. So I replace the timing belt and found out the previous owner lost the bolt for the tensioner which made sense why the belt fell off. Replaced both belts, put a new bolt in. All the tensioners and pulleys were new so I left them be. Couldn't get the timing right but after three times of tearing it apart I finally got it right and everything back together. Now it tries to start, but won't stay running. I have fuel and spark. I'm thinking the fuel/air ratio is off due to fact of the aftermarket intercooler pushing more air and not supplying enough fuel. But before I get into that could it be something simpler? Any suggestions?
Do a compression test to see if you bent your valves. If the belt fell off when it was running, it's a good chance you bent a few.
Okay I was posting this as I as on my way to go buy a compression tester. In cylinder 2 and 4 I have 150 psi. Can't get any reading at all on 1 and 3
So send the head to a shop to get it resurfaced, buy a valve kit. Any thing else? Honestly it's just a flip vehicle so I don't plan on keeping it. So cost effective is key. Cheaper to replace the motor or rebuild the head?
