95 gst clutch problem
fiftystunter
Mar 22, 2008
orlando, Florida
I have a 1995 Eclipse GST and i was driving the other day and went to shift and the clutch pedal stuck to the floor. Cant shift into any gears cause the clutch wont engage any ideas on what is wrong???
it doesn't engage or or doesn't disengage? I am assuming you mean disengage, so that is how I am going to answer you. you have several options, the TOB could be broken *I have had one of the tabs break off mine before*, the clutch disk could have come apart and you might have a spring lodged in the PP, the master or slave could be bad, ECT..... my suggestion is check to see if there is fluid in the res. try to bleed it, if that doesn't work you are just gonna have to pull the trans and take a look.
