95 auto Tsi Engine Harness In 97 manual Gst
awzer2
255
Nov 4, 2009
palm desert, California
Okay i have been up ALL night searching..
I can't figure out weather or not a 95 TSI automatic engine wiring harness will work on my 97 manual Gst..i have not drove this car in a year because the harness is destroyed :sosad: it's my dream to be able to drive this car again,i have to been to hell n back with it. I have the original harness from my gst still too. Here are my provisions...
1.95 tsi eprom ecu
2.97 gst stock ecu
3.Gst wiring harness;mangled beyond repair with many wires intact.
4.Tsi engine harness;everything in tip top shape.
Someone please tell me a way to make this work,i also have a 95 Eprom that came with the harness i would love to get dsm link and use it.
Please HELP!?:sosad:
anyone have the expertise?
HELP??????????
a few connectors on the 95 will not connect to the sensors in the 97. BUT depending on the year they might, as im doing a MT to AT swap in a 99 and got a 97 harness and the purge valve connector is different so you may get lucky in that since, but you have a CAS as the 95 doest so you may need to get that addaptor from RRE.
yeah that guide brian and his brother did, helped me figure out what that one connector was for (purge valve) same color wires, but different connectors.
