93 Tsi Will Not Start Now?
dsm r 4ever
Jul 18, 2008
st.paul, Minnesota
Hey guys, so i just got a 1993 TSI 3 days ago.
it was parked for three years, so with a new battery and some other parts we got it stared drove it for a day or so and this morning it would not start? it has spark but no fuel???? dose the fuel pump just go BAD???? whats do i look for, and the funny thing was that there where two 1g gsx driving by the night before cars like that just don't dive by my place and the doors where unlocked.... PLEASE HELP ME I REALLY WANT TO DRIVE IT!!!!!!!
are saying it isnt getting fuel or asking? if its a known fact that fuel is not getting to the rail then its most likely your fuel pump.
YEAH it not going to the Rail...... but it just went bad over night? you would think it would go when your driving?
Again, if you have no fuel to the rail, check for 12 volts and a good ground to the fuel pump. If you have both, then yes, the pump can go bad overnight. You can even drive to the grocery store and when you get back in your "perfectly" running vehicle, it won't start.
Verify whether you have volts, ground and pressures and let us know.
Good Luck
I assume that is a viable question. In answering, it can indeed be rust or perhaps a bad sector on the commutator or any other numerous things that can go bad. In diagnosis you verify everything with volts, pressures if required and ohms and amps if need be.
We can only offer suggestions as we are not there.. If you perform these tests and post the results we will do our utmost to help you in your repairs.
Good Luck to you
