93 talon 4g63t 7bolt head gasket (upper gasket set part #?)
killerwhale
128
Aug 10, 2007
Victoria, BC, Canada
Does anyone have a list of all part #'s (or a package) for the gaskets, injector rings, etc needed for an overhaul / head gasket replacement on a 93 eagle talon 4g63t 7-bolt trans.
Effin head gasket couldn't have started to go at a worse time.. I'm going to Italy in a couple of months and still trying to save up for the trip.
Also I'm not sure if the timing belt was ever done so I was thinking I should replace that too (and anything else necessary in the process).
Any tips would be greatly appreciated as I've never attempted anything this big before. I have a haynes manual and an $800 budget (CAD) set.. Hopefully that's enough because the mechanics I've talked to want around $1500-2300 for the job (including parts).
Thanks
Nevermind I found a pretty decent overhaul package. Only parts not incl. are: Throttle body gasket, Throttle body elbow gasket, Injector O-rings and insulators, Half Moon seal for the valve cover.
MD971620
In case anyone else needs it.
the head is the same as a 90-mid 92. I just did a headgasket on mine (cometic) headstuds you have to use 7-bolt studs (I switched to ARP). Cometic sells a kit, if not topline is ok for a stock rebuild or a evo 3 metal headgasket and topline seal kit.
