92 Tsi Fouling Plugs
92electricblue
Jul 13, 2008
DIXON, Illinois
I Have A 92 Tsi. My Mods Include 2g Mass Hard Wired, Afc Neo, Bc 272, 3 In Exhaust, Fmic, Evo 8 560cc, Supra Fuel Pump, 20g Turbo, Autotrans With Shift Kit And Stall. My Problem Is That The Car Ran Ok On The Way Home From The Shop After The Rebuild Now I Was Messing With The Numbers On The Afc And Now I Have Fouled Out 12 Plugs. I Put The Numbers Back The Way I Had Them After I Left The Shop But Still I Fouled Out The Last Four Plugs. Iam Getting A Check Engine Light And The Idle Is Erractic And The Car Wont Rev Past 3500 Rpms Can Anyone Help
autozone cant scan the 1gs. You need to have a multimeter with a sweep or a palm datalogger. there is a how-to on vfaq.com. Im amazed with your mods that you have no datalogger(mmcd), get one immediately
iam going to do the full line pressure mod for my trans... iam thinking that my mas could be wired up wrong, but also the car is smoking pretty good and when i went out to the garage today there was a puddle of antifreeze under the car, but i also saw that the thermostat housing gasket was leaking so i changed it and ran the car for awhile no leaking but i am going to check later when it cools
use the search! you can find the software by googling MMCD and get it from that site. Youll need a logger cable which you can make via (mmcd or ceddy.us) or ebay ($30) and a compatible palm (any serial cable one) and you are good to go
i think i figured out the problem i had the shop hard wire my 2g mass and i think the wires are wrong cause i got a scanner on it today and i was getting mass air flow code, intake air sensor code, baro pressure code which are all wires you have to match when wiring the mass plus i changed out the mass with the one in the car and the car revs up now. so i bought a plug and play harness
