92 Tsi cant get to start at all
25psi_talon
75
May 28, 2009
Cedar Falls, Iowa
so bought this car running awesome, let it sit in the garage over winter
now it wont start :(
have used starting fluid
changed ecu's
all spark
fuel pump is on
compression sounds fine
changed mafs
cranks all day but will not start......
any ideas?
ps not sure y it decided to choose 2g.....
Is the boost guage going to zero when you turn the key on. 1Gs are notorious for ECU caps leaking.
Yes new gas, changed ecus all 4 had spark, have to mess with the cas, I'll check the coolant sensor, thanks for the inputs
Alright, so did some messing around today, turns out if I unplug the injectors it runs but shitty like LOL but when there plugged in it just cranks any ideas?
