91+ cas into 90 Car HARDWIRING
1990talontsi
179
Jul 26, 2008
boise, Idaho
So i belive my cas is bad in my 1990 eagle talon
i recently put in a new motor from a 91+ and i reused the intake manifold and cas and coil pack
one day my cel was going on and off but the car was still running good so i didnt pay any attention to it but the next day my car didnt start
i have access to a 93 car and i took out part of the harness so i can get the different clip for the cas
does anyone know how to directly wire it in?
what colors go to which?
that made no sense at all
i need to know how to wire a 91+ cas into a 90 engine harness
i know it will work people have done it before i just need to know which wires go to which
91 harness-----------90harness
large black-----------black
large red-------------red
small black-----------yellow
white-----------------white
can anyone confirm this is the right conversion
i searched the crap out of this site trying to find info and thats what i came up with
i think thats how it goes
im trying it tommorow and hopefuly my car starts
so i wired in the 91+ cas and i got fuel to squirt out of the injectors by spinning the thing on the end
i put it on my head and tried to start the car and it wants to start but it doesnt
is my timing off causing my car not to start or would it atleast start up but not run really good ?
anyone help?
i told you that you had a different problem,guess im stupid....how is the car running?
well the cas is now squirting fuel out of the injectors
but the car is still not starting
i think the timing is off
it almost starts but doesnt
line all your timming marks up(cams and crank marks)and see where you sit.if all marks line up you should be tbc on #1 cylinder,if not you might have jumped timming.
i just went out and did that and the timing is all fine
this is sooo confusing man i dont know what the hell is wrong with it
it kinda tries to catch and start but it doesnt start
i dont know what could of happened over night that made it not start
my galant ran fine one day,next day would not start.let it sit for a day and still no start.pulled the plugs and they looked wet(flooded maybe),left the plugs out for a day to let the cylinders dry out.put new plugs in and had a friend crank the car while i moved the cam angle sensor back and forth and it started.reset the timming and havent had a problem since.my car would almost start just like yours and this was my fix,just an idea.
i have a data logger but its not working idk whats wrong with it i think im gonna buy another or something
and i tried retarding the cas it still didnt start
and the spark plugs are in the correct order
yes maam
ill pay you to come figure out my problem
i really need to get this running
ive had a streak of bad luck with it
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
