'91 AWD 5-speed
aaronspeed
47
Jun 22, 2008
Marengo, Ohio
This car is my sons and we rebuilt the engine and installed it a couple weeks back. When we start the car it runs great but we noticed that the Oil Gage works backwards to other cars we have owned. The gage starts on High then goes to the middle and when the oil warms up it goes to low. The oil light seems to work fine and we have verified the oil pressure with a external gage. We switched the oil sender with another used unit we had from a parts engine and it does the same thing. My guestion is should the dash gage start on low or does the Talon gage start high then drop. I am trying to figure out if both of the senders we have are bad or am I looking at a short in the harness to the gage. Thanks for any help.
I recently encountered this same problem on a 94 AWD I put a head gasket on. 90,000 miles for reference (all stock) The gauge would start high and then once the oil warmed, it would sink just above the minimum mark. I also verified the oil pressure using an external gauge and everything seemed normal. At warm idle it had 20 psi of oil pressure, revved up to 3000 rpm it would see around 60 psi.
After searching this site for a couple hours later that night I came to the conclusion that this is normal on a motor with the balance shafts still in. I drove the car for 2 weeks after that just to be sure and returned it to the owner. Still no problems.
If oil pressure drops off to the low side while cruising, suspect a problem.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
