Resolved 91 1G - Troubleshooting 2 ECMs' codes - zero then steady 6 or 9v. No pulses
Yardfudge
Sep 18, 2023
Beavercreek, Ohio
Hello,
Newbie here. 1991 Plymouth Laser, 1G SOHC non-turbo, Dayton Ohio. Ran great .... then suddenly it just turns over but doesn't start.
Injectors not firing, no spark, fuel from fuel pump into rail. Tried taking ECM trouble code but it had no voltage. (inside of ECM looked OK.) Replaced the ECM ($40 eBay, its insides look good too), and it now reads a steady 9 volts, try to start it, then it reads steady 7 volts. Car battery is 12.5, fully charged. All fuses fine. Per Haynes manual this means both ECMs are bad ... but given its 32yo and DSM's reputation for poor wiring, I wonder if it's something else. Or do I try another ECM?
I searched but didn't come across this problem in the forum. Ideas? Is there a 'Master 1G ECM Troubleshooting Guide' somewhere? Can I check the wiring going into the ECM? Thanks.
Where are you checking voltage? Post a pic of the ecus so maybe somebody can spot an issue. If it's not a bad ecu then I wonder if it's a bad MPI relay as that is involved in ecu power supply.
Thank you for the 'MPI relay' hint which lead me to https://www.dsmtuners.com/threads/1g-basic-ecu-mpi-relay-circuit-function.435961/ where I was able to confirm both my original ECU (no CEL, that showed steady 0 VDC fault code, no heart beat) and a used-ECU-from-eBay (no CEL, that showed a steady voltage when taking fault code, no heat beat) were both bad. Voltages and grounds on the ECU and MPI Relay wiring were good as per that guide.
Oddly, both ECUs looked clean on the inside, no messy capacitors (but I'm no electronics technician, I'm comparing only to what I see on https://www.ecmtuning.com/wiki/ecurepairhome).
I'm going to try another used ECU from eBay since that seems cheaper than finding / paying a shop to troubleshoot everything further.
I am slightly concerned something else in the car is creating ECU problems, as https://www.dsmtuners.com/threads/troubleshooting-fried-ecu-components.116585/ suggests but since I'm getting two different ECU effects and not seeing damaged drivers, I'm thinking its not from "from wiring problems (shorts,etc) or faulty actuators/solenoids"
So this is a 1.8L 4G37 we are discussing? MD159561 ECU?
If you're not getting a heart beat (on/off repeated) or an fault code it doesn't sound good for the state of the ECU.
Yes, MD159561 ECU.
I think I did as much troubleshooting as I can to confirm the original (to me) and a used one from eBay are both bad but in different ways. (see other reply for details). Unless you've another idea I'll just try a 3rd ECU.
Yes, MD159561 ECU.
Without seeing them I have nothing else to go on. From your description it's not clear if the original was failing to turn the MPI on or not. Sounded like the second one did but had some other issues.
I think I have a good one in the basement. I'll check when I have a moment. (I do, PM if your interested)
I installed a remanufactured ECU from eBay and it started right up. Kudos to https://www.ebay.com/str/flowersautowreckers.
Thanks for the replies.
Now to work on the dozen non-critical issues....
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
