90 vs 92 tranny help!! please
yupinmywhyte_t
Sep 18, 2008
nampa, Idaho
i put a 90 tranny in my 92. can i use the shifter, shifter cable bracket and cables from a 90 laser non turbo 5 speed its got a 4g63 in it
wheni swapped mine from a 90 to a 91 the only thing i used was the bracket on top of the tranny that holds the cables, and havent had any problems
When I swapped mine 90 to 92. I tried to use all from 90 but won't go into 1 and 5. I changed the bracket and had to adjust the shifter to make it shift into all.
putting a 91+ in a 90 is a lil more difficult but a 90 in a 91+ you just have to change the brackets
i didnt even use the arm, just the bracket, and it works fine, not using the arm just makes the throw a little shorter
so on monday im going to go buy the bracket cables and shifter from a 1990 4g63 non turbo laser 5speed hope it works. any suggestions???????
