90 tranny in a 92
Danks
81
Dec 23, 2003
The Beach, New Jersey
i might be gettin a 90 awd tranny to put in my 92.... what are the issues with the shifter cables/brackets????]
thanks
cant i just use my tranfercase? and theres noway to use the stuff on my car already?
your shifter cables in your 92 are longer than the ones in a 90.also are you also getting the 90 transfer case?because your 92 transfer case wont work with the 90 tranny,do to the spline count.
90' tranny and TC = 22 spline
91'+ tranny and TC = 23 spline
Yes there are
1. Remove the main shifter tranny bracket that is attached to the shaft and replace it with a 91'+ bracket, the hardest part is to remove the roll pin holding the bracket to the shaft, almost impossible on an older tranny.
2. This is easier but a bit of hack, drill a hole at about 5 cm from the shaft on the 90' bracket and bolt your cable there.
You can swap in a 23-spline output shaft into your new tranny to work with your existing xfer case. You just take the end cover off, pop the c-clip off the viscous coupler, remove and remove the one ball bearing and push the shaft out and replace with your 23-spline shaft.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
