90 tsi wiring help cant get the right combo
eldsm
Feb 7, 2008
salinas, California
so i just got this car not that long ago so wrking on them is weird its a 90 eagle talon awd tsi the problem is that i cant get the ignition wiring right i have searched every wear and tried like 5 different combo like head(left to right) 4321 and on the ig coil 1234 and couple more well any one know just the stock normal one i have to go to wrk tomorrow so i really need help thankx:thumb:
Spark plug wire routing - if you removed your spark plug wires without paying attention to the routing, don't worry. On 4G63s, the spark plugs are numbered from the timing belt/driver's side - #1 is closest to the timing belt. The connections to the coilpack are 4123, with 4 being closest to the head. See this pic. Note that since 4G63s use a waste spark system that fires 1/4 and 2/3 together, you can also hook the wires to the coilpack as 1423 and 1432 and it will work fine. Note that wire #3 is longer than #4 - shortest to longest, they are 1243.
