TuRBoTaLooN
- 760
- 18
- Apr 27, 2005
Denville,
New Jersey
Yesterday I picked up a 1990 talon tsi fwd for $500. Body is straight, no rust, new suspension, 90% stock except for 3" DP, and brand new 16g. Interior was 9/10 as well. 130K on motor and body. Only problem is the car doesn't turn over. The kid I bought it from said it ran fine for a while, felt strong, no shakes, rattles, etc. while driving. Then one day while driving, the car just shut off. He took it to some shop and they said the head seized. I have no idea how they figured that out...they apparently didn't take anything apart. They just looked at it. The seller also stated that there was an oil leak from some hose (I'm assuming the oil return line). But there was still some oil in the car.
The car still needs to be towed to my house, and I have a few things I want to check. When trying to start the car, it cranks, just doesn't turn over. I took a quick peek at the timing belt and it looked more than fine. I'm going to do a compression test. Check for spark, check to see the fuel pump is coming on. Check fuses and wiring.
I will post the results of my findings after these tests, but also wanted to get advice as to other things I can look at to help diagnose the issue. For example, if I determine the fuel pump turns on, how can I check to see that the injectors are pushing the fuel? And if the head is seized up as I was told, how do I check for that? Thanks ahead of time for any help.
