90 Oilcooler on a 6bolt 92?
my_gst95
569
10
Nov 13, 2002
Sacramento, California
I recently got a 92 6bolt/4bolt and I'm wondering if the 90 air-cooled oil cooler and oil filter housing will bolt up to the 92? I'd like to do this mod also so I can run a 90 N/A waterpipe and waterneck since the TO4E on it is oil cooled. Should make things alot cleaner under the hood.
my_gst95
Yes the oil cooler will work, but you will need the 90 oil filter housing to hook up the oil cooler.
my_gst95
it does wonders in this heat as well.... all my fellow DSM onwing friends cant beleive my oil pressure.... and i love that i can stow away almost 3/4 of a quart more...
Did you guys use a non-turbo water pipe? I am to that point on my 1gina2g swap and like my_gst95, I have an oil-cooled turbo.
I have a non-turbo water pipe but it is a little rusty inside...any ideas on how to get that out and protected so it doesn't rust again?
Thanks,
MM
