90 Gsx Radiator Fans Wont Spin
Streetsweeper21
140
Jan 11, 2006
Atlana, Georgia
Hey watz up? i got a 90 gsx and all sudden car is over heatin and i look at the radiator fan and it was like off stuck incravin into the radiator and off the thing that spins it i tried to put another fan in there but it aint spining what can i do to make them spin thanks
did you check the radiator fan thermo switch, on the lower radiator tank? and all related wirring/relays and fuses?
lower radiator tank??? the relay cant even tell if its bad
When my thermo relay went bad on my fans, I just turned the heat on low and left it on, it kicked both of my fans on for the time being until I could wire them directly to the killswitch.
