Radiator fans wont kick on?!
talonation777
200
Nov 15, 2005
Niagara,
So I was driving home from my apartment to my Mom's house, I hit the highway and I was cruising along, and I noticed that my temp gauge was inching up over my usual engine temperature. I didnt think much of it, and just thought my fans would kick over and feed some cool air to bring down the temperature. Wll, as it turns out, my fans never kicked over. I popped the hood when I got home while the car was running, the engine was at about 190-210 degrees F. I knew this was a problem becasue usually I'm running just under 190. The fans never kicked over! I turned off the car, and turned it back over, and still no fans kicked over. I even turned on my air, and still nothing. Can anyone give me some advice. This hasn't happened before, so its new to me. Post your advice and opinions. Thanks in advance.:dsm:
That never crossed my mind. I was thinking it might have been a dirty connection. I'll definitley look into that. Thanks alot man, I appriciate it.
Your fans will turn on when you turn on your a/c right? I had this problem as well and it turned out being a blown fuse. Good Luck.
