1990dsmkid
- 692
- 98
- Jun 14, 2012
Bellwood,
Pennsylvania
Alright I just replaced my throttle body shaft seals and reinstalled e erything. I did blt and found 2 small leaks and fixed them. I did set my tps volts to .48-.52 according to fsm. The isc coils all read 29.7 ohms and I did remove it and had someone turn key to on position. It spun and moved so Im pretty sure its good. I then went ahead and started the car and let it run to get to operating temp so I could adjust biss if need be. Well once it started getting close to operating temp it started to surge ever so slightly and would get a little rough sounding then it shut off. I figured I would go ahead and try adjusting my ips. Well Im following the fsm and I cant get the resistance to read without jumping around so I added a ground wire along with grounding strap. Still had same problem so I grabbed a test light and clamped it on the ips and held prone on postive terminal. I spun the isp until the light came on then turned it another 15/16 of a turn. Will this work correctly in setting the ips? Tomorrow im going to try another blt and letting the car idle to temp. I just went this thing to idle correctly
