90-91 6 bolt turbo & N/T
sakrafice
217
May 28, 2003
Sumpter, Michigan
I searched for this, and its not what im looking for.
I have recently picked up 2 n/t 6bolt motors. I also have a turbo 6bolt block with the internals in it. now what im wondering what exactly is diffrent.... i know it has bigger rods, pistons but what about head? is it bigger cams, valves stuff like that ? because im doing a 6bolt swap to my 2g and was wondering if i could just use the 1g turbo head and be good to go, or just replace vavles and such, i planed on getting the head ported and building it up enough, but i just want to know what exactly is diffrent from the n/t and the turbo 4g63
thanks jesse. :thumb:
the only differences i know of between the two are as follows.
different compression pistons (rods and crank are same size as turbo on the nt)
no oil squirters in nt block.
cams are smaller in the nt.
cross pipe from water pump is different, as is the thermostat housing (neither have lines for turbo on nt motor)
thank you, I like, everyone else is wanting to do a 6bolt swap to there 2g. thats why i ask; and since i got 2 engines with tran's for 300 bucks im not complaining if i have to order turbo parts. like i said befor i have a turbo block with internals and am looking to take head,flywheel ect off n/t motor and use it on the turbo block. i know ill have more questions on how to do this swap but i know about the mangus site and how they did it but am not sure on what all the parts look like.... :cry:
well you'll have to get a new flywheel, the nt one just won't work for you. sorry.
i have been searching for a 4g63t engine for two weeks now.. due to limited funds.. i haven't been able to find one.
hmm, i herd it would but ill take ur word for it thanks.
I grabed them out of a junkyard, i got them cheap because my dad's friend owns it. how ever u should be able to pick up a n/t dirt cheap from any junkyard. i know were about 11 or 12, 1g's dsms are sitten right now with engines in them at this junkyard close to were i live.
