90 6 bolt swap, can I use T25 on it?
DSMLoverFromUA
115
May 23, 2003
Lodi, New Jersey
Ok here it is. I have a 97 GSX and my 7 bolt just walk on me. So, I bought a 90 6 bolt from this guy on tuners but he never gave me the turbo for it. So, I was wondering if I could use my original T25 on my 6 bolt? Will the oil feed line hook up and oil return line? Anyone has and input on this please help. I was want to get it on the roud as soon as possible. I khow is this does not work I will just have to get 1g oil lines and turbo and everything will work fine but I dont have the time nor the money so, please help.
Thanks
Mike
No your turbo will not "bolt on" If you have all of the lines, look into a 14b, they can be had for around 100~150.
Thanks
Mike
As long as you have the stuff from your old 7 bolt then it will work. You'll need the lines from the original motor.
A 14b can be had for pretty cheap if you shop around. However, I believe the t25 will work as my buddy just bought a 90 TSi and it came with a t25 :confused: . Dont know why the previous owner put it on, but it works.
Thanks so, I will go take a look at my 6 bolt and 7 bolt on the weekend and see what I can do. They are bought out of the car so it should not be too much of a problem. The only thing is that I have no clue where those lines for oil and water go to but that I can search. Its just that no one has posted anything on t25 and 6 bolt so, I could not of find anything. But Thanks.
