8cm Starion Housing w/14b ??
AWDphantomTSI
54
Apr 5, 2004
Allentown, Pennsylvania
Hey guys I was wondering if an 8cm Starion housing would work with a 14b? I know the O2 housing would have to be different but would I see any sort of gains from this? Any info is apprettiated.
Ed
I don't want to shatter your dreams but, The Star/quest Turbine housing is COMPLETELY different in all dimensions Reason being:
It is the wrong Flange pattern (bolt holes don't line up)
The Collector is too small
It is designated for the TD05 turbine wheel and Not the TD05H turbine wheel
The Wastegate Discharge route is very inefficient I mean we're talking 90 degrees of turbulent gasses trying to find a hole to squeeze out of.
I used to own 2 Conquests and for some resason or another we always tried too find a solution to getrid of the TD05 12A.:D
If you want a Turbine housing that will last damn near for ever, look for an Evo 3 or look into BEP's turbine housings.(bullseye power)
-Solid
:thumb: No problem at least you asked before making a foolish move, that may cost you in the future.
