1G -8 AN fuel feed line location
willyp42
60
9
Sep 28, 2016
Windsor, ON, Canada
Hey I got around to making my fuel line for pump to fuel filter. I can’t squeeze the -8AN fuel line following the stock line location in between the chassis and the subframe. what do most people do? It looks like hose can fit but not fitting. Do people just drop the sub frame? Is there a trick I’m not seeing?
thanks.
Run the line wherever you can. Follow the ebrake cables, tie onto that, then use self tapping screws and cable ties to secure them under the car up to the stock fuel filter area
If the hose is long enough, take off the hose end and feed it thru, then reinstall the hose end.
