7bolt rod on a 6bolt crank
stroked4G63
Apr 27, 2005
San Diego, California
:confused: Ok heres the deal, I have a built 7 bolt stroker motor that i built myself. Last weak one of my mains went out after the oil found a way out at the front case. I have since decided the hell with the 7 bolt and bought a 6 bolt long block. I have a stroker crank for the 6 bolt and i want to use my rod and piston setup from my 7 bolt. I have researched it and my eagle 6 bolt rods are identical to my eagle 7 bolt rods. I know i can use the pistons for sure i am not 100% sure of the rods. keep in mind the 7 bolt eagle rods use 6 bolt main and rod bearings. If i remember correctly the 1g big rods simple need machining on the wrist pin end to put the 2g pistons on in a stock rebuild. Any way here are both rod specs. Thanks for your time gentelmen!!
Mark
6 bolt eagle rods
length 5.900"
Crankpin 1.771"
"big end" Width 1.117"
weight 575g
Bushed fit pins full floating
7 bolt eagle rods
length 5.900"
Crankpin 1.771"
"big end" Width 0.038"
weight 550g
The 7 bolt rods will not work in 6 bolt because the width of the big end is different.The side clearance will be too large causing the sides of the rod to beat back and forth on the crank.
Thats the response i was expecting but I was wishing it werent the case! Anyway thanks for your time. do you think the 1g rods will hold atleast 400hp with the weisco pistons?
The 6 bolt big rods will hold 400hp no problem.
