75mm TB
syrushcw
296
Dec 12, 2006
Trumbull, Connecticut
I've read several threads about 75mm TB but like a dumb ass I wasn't paying attention that most of them were about 1g's. So I have a JMF SMIM flanged for a 75 BBK TB. And well I cant find a 3"/75mm tb elbow anywhere. Or for that fact a 3" Intercooler piping for a 2g SBR carry's one for the 1g. I talked to Jeff at SBR and this is what he told me to do "ou can make it work using a 90 degree coupler to connect the IC pipes to the throttle body. That is the easiest way to make it work. It does take some finageling" I was wondering what you 2g guys with 75mm TB are doing for the intercooler setup. Should I just grab the 2.5" intercooler setup but that's kind of a waste of a 75mm tb huh?
hey I was running a 75mm tb on my magnus. The best way to do it is to buy a 3inch 90degree SILICONE coupler off ebay, run that straight off the tb and connect it to your ic piping. Hope that helps...
6bolt are you using the Dejon Upper (IC to Throttle Body) Pipes for Big Front Mount? If so do you have a pic?
Ya, I'm using the Dejon 3" FMIC Kit.
I have additional pics in my profile section and my avatar pic has a pretty good shot of the upper pipe as well.
