7 bolt 4g64 wideblock flywheel
ggsx
Feb 10, 2022
denver, Colorado
So my dilema is that i have 4g64/63 7 bolt swapped starion useing the stock trans, when i originally put it all together i know i used the flywheel, pressure plate, and clutch disk that was original to this 4g64 short block. which came out of a 94 mighty max. Anyway im in need of somthing that can hold more power problem lies in that i cant seem to find any kind of heavy duty clutch kit for a mighty max LOL. i know if i had a 6 bolt block then i could use all starion components. Long shot but anyone happen to know of a combination i can make work?
Centerforce sells a dual friction clutch for the mighty max that will hold about as much power as the km132 will handle. I swapped my mighty max to an AR5 trans because the stock truck clutch and flywheel couldn't hold the 10.5:1 2.3L before it made boost LOL
aww dang i looked them up and all the options they have are no longer available.
