6bolt swap xcase starter bracket
byebyev8
344
Jun 17, 2004
kenosha, Wisconsin
I'm almost finished with my 6bolt swap and I wounder what do u have to grind off on the starter mounting bracket and the transfer case. Pics wound be great...
Can you put the starter up there and see what you would have to mod, take pics, post, and then we could go from there. You are using a oem 1g starter? 1g oem flywheel or flexplate? T case 1G, Dou you have mounting brackets for all, or do you have to buy or fab new ones?
I'm using the 1g flywheel, 2g starter t case and starter mounting bracket.
On the 6bolt swap tech guide, it says to grind down one of the transfer case bolt holes and the 2g starter bracket.
