6bolt in 95-99
Grnrmpecas24
Feb 10, 2003
Ok i could look around but everything looks a little too confusing. I dont need to know how, but what. so here it is:
List EVERY part i need to put a 6 bolt into 95-99.
Thank you,
Jared(a victim of crankwalk)
:talon:
Hey,
I just tried out this new feature, its called the search, located at the top right of your tuners window, Its Brand new and SOOO COOL.
you clikc it, and type it what you want to find, and it searches the archives and finds the thread with the key words you specify...
03-03-2004 01:34 AM
http://www.magnusmotorsports.com/1g2g.asp
that is a link for the 1g into a 2g swap........there is everything you will need to know on what u need from the 1g, and what u need from the 2g.....is tells you what u need if your doing a 6 bolt swap wiht a 1g head, or a 6 bolt swap while keeping ur 2g head.....hope this helps.......here is a little info on it......
1G CAS (91-92 Optical Effect, 93-94 Hall Effect)
1G Oil Cooler (90-92 MD 157670 6bolt water cooled oil cooler)
1G Water Pump
1G Oil Pump/Front Case
1G Timing Belt necessities
2G Engine mount (modified) use 2G engine mount trimmed, with 1G tensioner arm
1G Timing Belt Covers (modified)
1G 90-92 6-bolt block (with whatever internals)
1G 6-bolt Flywheel
2G Starter Mounting bracket
1G Water Pipe
1G lower radiator hose
1G Thermostat housing/ Water Neck
1G 6-bolt oil pan Balance shafts (remove them or keep em, its up to you, we take them out)
2G Alternator
2G Power Steering Pump
2G A/C 2G Belts
If you look at the website it is alot more detailed...........most of the 2g sensors, will be reused, with exceptiong for the CAS.....if u have any questions feel free to PM me.....good luck man.......the swap isnt to bad, ive done it and so have many, long live the 6 bolt....haha...good luck
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=94953&highlight=6bolt+swap
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=105178&highlight=6bolt+swap
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=107180&highlight=6bolt+swap
