95 cas in a 99 dsm
horizontalkev
Supporting VIP
1,000
Jun 28, 2010
great bend, Kansas
I'm dropping a motor from a 95 gst into my 99 gsx and the issue I'm having it the fact that the Cas is on different sides of the head. Rewiring the 95 cas into my 99 harness won't have any negative downsides will it?
95-96 used a inverted cas signal some rewiring of the ecu connectors will have to be done. Or remove your 99 intake cam and drop it into the 95 head and use your 99 cas sensor
If u use the 95 cam sensor. Yes. U will need to rewire. If u remover the intake cam and replace it with 1 that has the provisions for the 99 cas. Then no
when using the 95 cas with 99 blackbox ecu what ecu rewiring do u need to do and what about the injector pins? I read somewhere that i'll need to swap injector pins.. or could I use my 1g 6bolt intake cam on my 95 head?
