95-96 and 97-99 conversion cas wire
dsm1997
Jan 8, 2011
Windsor, ON, Canada
hey guys, im working on a 6bolt swap for a 97 gst and i bought a cas conversion wire for it, but the thing is i was sent the 95-96 cable. how i know is becuse the wire has two clips at the end, i tried to contact the guy and hes not answering for some reason. so now wht do i need to do to get this working? which wire do i have to change with to get this working please help asap thanks!!!!
these are the pictures, please help asapp
ahhhh come on guys any help here?
You should be able to just swap plug wires, same as anyone doing a 2Ga/2Gb ECU or CAS swap.
Looks like the 2ga and 2gb plug/wiring setup is the same.
RRE Instructions
It is... Sort of..
The wiring part is the same but the connector itself is different. The connector for the crank (the one with the three wires going to it) is fine, but the single wire one for the cam you can just cut and splice to your stock wiring. Sorry I have no idea where to get the connector for the 97-99 CAS from.
