General 680 injectors MAFT and SAFC tuning help please.
Mits3gts
188
Sep 30, 2004
bellingham, Massachusetts
I finally got around to installing my pte680's.I am using the maft to get the base set,which should be good.my trims look good at around 110%.I am tuning for 18psi on the evo3 using mostly the safc,now my question is this.
is it normal to richen up the afc at 3-4k then lean it out after that? I was getting hi knock counts in that area(3-4k) but would studder really bad in the upper rpms(rich).heres what my safc looks like now,thanks a lot for the help also i have checked for boost leaks and such,everything seems fine.
lows-all zeroed out(using the maft)
highs-
1k 0%
2k 0%
3-4k 15%
4500 10%
5-7k -10%
mods are in my profile,running 15 psi..someone please tell me what needs improvement,i am having quite the time tuning my 680's..thanks
TIMA RPM KNCK INJP O2-R
33° 3313 0 4.10ms 0.68V
32° 3344 0 6.40ms 0.39V
29° 3344 0 7.17ms 0.84V
28° 3406 0 7.94ms 0.86V
26° 3406 0 8.45ms 0.88V
26° 3594 0 9.73ms 0.88V
25° 3594 0 10.75ms 0.88V
22° 3563 0 11.78ms 0.88V
21° 3656 0 13.31ms 0.90V
21° 3719 0 14.08ms 0.90V
19° 3844 0 15.10ms 0.90V
19° 3750 0 15.10ms 0.90V
19° 3906 0 16.13ms 0.90V
18° 3844 0 16.38ms 0.90V
18° 4094 0 16.38ms 0.90V
18° 4156 0 16.38ms 0.90V
18° 4063 2 16.13ms 0.90V
17° 4281 2 16.38ms 0.90V
17° 4188 2 16.38ms 0.90V
17° 4281 1 16.38ms 0.90V
17° 4438 1 16.13ms 0.90V
18° 4531 1 15.87ms 0.90V
18° 4563 1 15.62ms 0.90V
20° 4500 6 15.62ms 0.90V
18° 4563 6 15.62ms 0.90V
18° 4781 6 15.87ms 0.90V
18° 4656 6 16.13ms 0.88V
18° 4844 6 15.62ms 0.88V
17° 4781 5 15.87ms 0.88V
17° 4906 5 15.87ms 0.88V
17° 4938 5 15.36ms 0.88V
17° 5063 5 15.36ms 0.88V
17° 5063 4 15.62ms 0.88V
18° 5156 4 15.36ms 0.88V
20° 5125 5 15.10ms 0.88V
20° 5375 5 15.36ms 0.88V
20° 5313 5 15.10ms 0.88V
20° 5313 4 15.36ms 0.88V
21° 5469 4 15.36ms 0.88V
20° 5531 4 15.36ms 0.88V
20° 5594 4 15.36ms 0.88V
21° 5594 4 15.62ms 0.88V
21° 5625 3 15.36ms 0.88V
22° 5719 4 15.36ms 0.88V
21° 5719 4 15.87ms 0.88V
21° 5813 4 15.87ms 0.88V
21° 5781 4 15.62ms 0.88V
22° 5938 4 15.62ms 0.88V
23° 5906 3 15.36ms 0.88V
23° 5875 3 15.36ms 0.88V
23° 5969 3 15.62ms 0.88V
23° 6094 3 15.87ms 0.88V
23° 6000 3 15.62ms 0.88V
22° 6000 2 15.62ms 0.88V
22° 6031 2 15.36ms 0.88V
22° 6250 2 15.10ms 0.88V
22° 6313 2 15.62ms 0.88V
22° 6313 3 15.62ms 0.88V
alright thanks alot for the reply,you think if i add the fuel i can turn the boost up some more?just wondering if i have head room with my timing curve..thanks again
You should lean out your highs quite a bit. Im at about -15% on 650's with a fp3052
Try starting there and working down. 680's is a lot of fuel for that turbo. 550's would work much better. What are you using to tune with? Ie logger wideband?
i am using a logger,i also posted my log and it seems that i need to add some fuel because i have small counts of knock 4k and up...unless i am getting rich knock..
He doesn't need to lean it out so much because the MAF-T is already compensating for the Injectors.
Mits3, just tune for no knock. Also it's very unlikely you are getting "rich knock".
