SAFC/Maft settings for 680's
selmerguy
1,810
23
Nov 14, 2004
Killeen, Texas
I have been tuning alot latley and tring to get my car running good again with the stock 14b. I have my maft set for 680's and my idle tuned with the maft aswell. I had to lean it out a good bit to adjust for the dead time with the 680s. But I have it around 14.7:1 at idle. Anyway of my high throttle settings I still have it at between -40 and -35 % from 3000 rpm on. The car runs good and only knocks when it gets hot. This puts me around a 11.3:1 afr through boost. I am running 20 psi untill the turbo tuckers out(around 6000) I would not think that I would have to pull that much fuel with the Maft allready adjusting for the 680's. I am sure the injectors are fic 680's but that seems like alot of fuel to be pulling. Any ideas or comments?
what kind of fuel pump and reg. are you running? and whats the fuel pressure? also what are u using to tune datalogger?
