60k Mile Maintenance
MR2-GTS
57
Aug 27, 2004
Queens, New York
Hey guys I just got my 97 GST with 57k miles it didnt come with a Owners Manual, can someone please tell me all the parts I need to change at 60k miles. I am trying to get the timing belt done so I wanted to know if anything else needed to be relplaced. Thank You.
excellent job at getting that 60k done. your car and pocketbook will thank you in the long run. take care of her and she will take care of you, we need more people like you who know how to take care of their cars. you get a :thumb: in my eyes.
All the things in this list on here. The HG and ARP's are for just replacing them for the ability to run higher PSI. If you are leaving the Head inplace, leave them out.
Get all of the belts and such. If you know anything about the pulleys or tensioner you can maybe leave them alone this time. But the Water Pump should be replaced with a OEM kit only. That way you can make sure you have bought a NEW pump not a remanufactered one.
#207-4203 95-99 ARP Head Studs (11mm - 12-Point Nuts)
MD972050 Water Pump Kit (Pump, O-Ring, Gasket)
MD349347 Mitsu Metal-Layered HG (Not the EVO VIII HG, that is a different OEM Part #)
MD372536 Cam Seals (2 are needed)
MD186785 Spark Plug Well Gasket (4 are needed)
MD186784 Valve Cover Gasket
MD050536 Half Moon Gasket (1)
MD326059 Timing Belt
MD182537 T-Belt Tensioner Pulley
MD308086 Auto Tensioner
MD156604 T-Belt Idler Pulley
MR984778 Balance Belt
MD192068 B-Belt Tensioner Pulley
-or-
Balance Shaft Eliminator Kit:
MD103722 Balance shaft Bearing (Rear)
MD040597 Balance shaft Bearing (Front)
MD092785 Balance Shaft Cap (Plug)
MD098626 Balance Shaft Stub Shaft
