DSM Chase
- 778
- 52
- Sep 19, 2011
Senoia,
Georgia
Installed a 6 bolt in my 95 GSX using the cas adapter harness to the 95/96 cam and crank sensor plugs, Car starts and idles very rough and has no vacuum... Cant figure out the Firing order and I set the cas properly base timing is around 5 DEG, Im using a 2G coil pack and 95 ECU with link.
Someone help me out ive read and read.[DOUBLEPOST=1407816694][/DOUBLEPOST]Using ecmtunings recommended firing order for non 95/96 cas with 95 ecu, I'm using a 1G green top cas with 6 bolt head, cas is Rotated so it's NOT 180 out... All plugs are black and car is misfiring.[DOUBLEPOST=1407846565][/DOUBLEPOST]Using this harness to the 1G cas from cam and crank sensor plugs off harness.
WTF
I guess blt's are always in order. Glad you figured it out man
