6 bolt swap?? help
skatershawn
1,271
13
Feb 27, 2009
Austin, Texas
ive posted already i was swaping a 90 6 bolt into a 93 n/t
found out what i needed but wanted to ask for some more help?
i was told to just switch out these parts from the 90 with 91-94's:
Cam Angle Sensor
Throttle Body
Coil Pack
Throttle Positioning Sensor
Idle Speed Control
Power Transistor
I was told to replace these and it would work perfectly but ive read a few other places to just replace the CAS, Coil Pack, and TPS!
IF i could get some help on what i NEED to replace i would greatly appreciate it!
Thanks!!
See here: http://www.dsmtuners.com/forums/1g-n-t-tech/55457-installing-turbo-4g63-into-nt-4g63.html
You're gonna have to do a bit of modding, because the 90 engines had different throttle body setups with their ISC and such, those items aren't gonna be listed in the turbo swap thread because its usually not a 90 engine.
The 90 engines are the oddballs of the group, so some things are different. You WILL need a new ISC, I can tell you that for sure. You can't use a 91-94 ISC in a 90 engine. So read up on the differences between the 90 engine and the 91-94 engines.
Wow Ptown. I just looked at the thread dates... Good job bumping old threads.....
