6 bolt swap HELP please
DEFIANTgst
Mar 22, 2010
east islip, New York
in the middle of putting a 6 bolt into my 98 gst.... everything is pretty much in and together only problem i am having is the car is throwing up a p1400 code which is something with the mdp sensor, the one i have is brand new and i have it teed off the brake vaccum line.... woudl it be better to drill out the intake and stick it in there bc i have a 1g intake on the car, other problem im having is the 1g intake mani didnt have a spot for egr and im also throwing a code for that anything you know will help tryna get this bi*** threw inspection n on roaddddddd
if u can tell by what it says on the mani it says eci multi than turbo with intercooler under it.... on the valve cover it says mitsubishi dohc 16 valve
ok ill take some pics post them up tomorow.... is there anyway of getting around emissions/ egr
When i had a MDP sensor i had it hooked up from the vac line,that goes from TB. and the sensor was laying on the intake manifold.. Had no codes...... Try to reconnect it,and disconnect the battery for couple of minutes.... it might help to get rid off the CEL
yea im in new york and obd2 cars gota get pluged in so you cant really look it over i own a shop so unfortunatly that wont work, and the mdp ive done that about a thousand times i disconnect the battery everynight.... what i really need is a 95 shell
Well i need to keep the cel light off... The egr is only one of my problems the car has no cats no pollution im thinking of just finding a 95 shell to make my life a whole lot easier
