6 Bolt SBR Stage 1 Shortblock w/ 2G Head - What do I need?
1sickgst
80
Jan 12, 2005
Sweetwater, Tennessee
Hey all. OK, first, please don't come down on me for not searching. I searched and everything I find gives links to RRE's site and I've looked it all over. I'm just kind of slow and need it in detail.
So, my 2G crankwalked and I'm going with a stage 1 short block from Slowboy Racing. I'm going to put my 2g head on it for the time being. I need your help in letting me know what all parts I'll need for the install. I've seen RRE's link...
6 Bolt Motor Install Into a 2G Eclipse
but it seems like there's some parts left off that list. For instance, the 1G oil pump/front cover isn't on there.
If any of you have a particular experience where you might have done the same thing, please let me know what I'll need. I'm definitely going OEM with timing parts and water/oil pumps. Any part numbers would be greatly appreciated. Thanks in advance for all the help.
Since I'm using my 2G head on the 6 bolt short block, can anyone tell me if a black top CAS will work with my 2G cams or do I need 1G cams. Thanks.
Thanks Joe, can anyone out there tell me if the 2G turbo (A/T) cams have the slot to allow a 'black top' CAS to fit.
Im pretty certain they do, you have a 97 so the CAS is in the same location as a 6 bolt. Pop the CAS off real quick and take a look, you will be able to see very easily if it does.
Joe
