6 Bolt into a 7 Bolt!!!!!!
Status
Not open for further replies.
dsm_basher
Apr 7, 2005
CDA, Idaho
Okay so I bought two 1993 eagle talons all wheel drive for 2000. One is running and the other had a timing belt slip and bent 9 valves and put a hole in a piston but the sleeves are okay. So my question is, I have a complete 6 bolt laying around with a huge hole in the block because the balance shaft blew out of it but did no damage to the internals. So can I swap the 6 bolt crank,rods,pistons, and complete head over to the 7 bolt. Thanks for the help!!!!
No...
1. Its not a honda engine there are no sleeves.
2. The crank bearings dimensions are different between them..
3. the cheapest way to make one run is to swap the 6blt head on the 7 bolt block...
I forgot to add buy one new piston or another used one.. ROFL
Status
