6 bolt head N/A vs T
The head itself is the exact same. Use the turbo camshafts and utilize the turbo oil feed line if you need to and you are set.
yea only the intake cam u need to change the exhaust cam is the same other then that the heads are no different then each other..
the exhaust cam is the same as a turbo exhaust cam is what i was saying LOL...
incorrect... i run the non turbo intake and exhuast cams from a 1g 5spd and after reading this post double checked on mitchell1. the cams specs for the NA and turbo on the intake are the same...
"Non Turbo & Turbo M/T l 1.3777-1.3974 In."
