6 bolt fly wheel 2g fwd tranny
l3igl3ang
539
Aug 10, 2005
ft smith, Arkansas
Hi i bought a 6 bolt engine and it has a 6 bolt flywheel on it and it came from a 95 gsx will this flywheel be fine to use in my FWD transmission or will i have to buy a 6 bolt fwd flywheel?
i figerd i better make sure b4 doing the swap
You need a FWD flywheel. Diameter is barely different. Everything will seem to bolt up fine...but when you go to fire up your car the starter won't fully engage.
Be SURE you get a flywheel that is properly stepped for your clutch/p.plate. If your clutch is old you might as well replace all of them at once.
It came with a new stage 3 clutch so all i will need is a 6bolt FWD flywheel? And would i have to get the flywheel stepped begin that the clutch is like new?
Sorry, never saw your second question. It's still a good idea to have whatever shop you buy from to prove to you that the flywheel is properly stepped for your application, even w/ brand new parts. Go to the link at RRE that I left in my first response. They cover the subject well.
