6 Bolt Crank & Cylinder specs ??
sweet97
2,386
18
Mar 6, 2004
auburn, New York
I am going to rebuild a 6 bolt. Can someone give me the stock main journal and rod journal sizes, not in metric. Same for the cylinder size. The motor has low miles and may still be within spec. Mark
If you plan on rebuilding your motor, I'd suggest getting a factory service manual or at least a haynes/chilton guide...they have all the info you need to do it right.
