6 Bolt Compression
cookmeup272
1,639
11
Jan 14, 2009
Utica, New York
What is the "perfect" compression on a turbo 6 bolt?
....weird...the guy im buying a motor from said its got 176 across the board.
He may have the block decked. Or the Head may have resurfaced. That would raise the compression.
Hrm. Mine are horribly low. Still runs great though.... I should possibly replace the pistons/Rings. ;P
But yeah. Upwards of 150 is good. Below 130 and it's time to do some work.
Before you do that. Have you replaced your lower fuel injecter seal. My compression was 145 all 4. Replaced the seals it jumped up to.160:thumb:
Make sure it's a turbo block. N/t compression will be 180+.
1G (90-94) T/E/L 1.8L NT engine
Compression ratio 9.0:1
Standard compression 185 psi
Service limit 131 psi
1G (90-94) T/E/L 2.0L NT engine
Standard compression 192 psi
Service limit 145 psi
1G (90-94) T/E/L 2.0L Turbo engine
Compression ratio 7.8:1
Standard compression 164 psi
Service limit 121 psi
2G (95-99) T/E 2.0L NT 420A engine
Compression ratio 9.8:1
Standard compression 170-225 psi
Service limit 100 psi
2G (95-99) T/E 2.0L 4G63 Turbo engine
Compression ratio 8.5:1
Standard compression 178 psi
Service limit 133 psi
2G (95-99) T/E 2.4L NT Spyder engine
Compression ratio 9.5:1
Service limit 146 psi
Thanks I was just gonna ask for that info:rocks::thumb:
I was searching for that
