highintenzity4
- 221
- 0
- Apr 30, 2004
Mission,
Texas
Hey is it possible to move to a 6 bolt with my 2g head? I have an a/t.. so what else do I need to do this job? Thanks...
Wolf just did one the same way....it will work fine. I am assuming it is going to be the 2g intake and TB?as long as you have the front case and oil filter housing for a 6 bolt and the timing parts You will be ok and good luck.highintenzity4 said:Hey is it possible to move to a 6 bolt with my 2g head? I have an a/t.. so what else do I need to do this job? Thanks...
Julia said:Wolf just did one the same way....it will work fine. I am assuming it is going to be the 2g intake and TB?as long as you have the front case and oil filter housing for a 6 bolt and the timing parts You will be ok and good luck.
Julia
