5th Gear assembly stuck on
paulb1320
47
Jun 9, 2011
Calgary, AB, Canada
I am tearing apart my tranny and I cannot get the 5th gear assembly off. The vfaq says it should pull off put it doesn't. I cant get a puller in there, and I tried prying but I am afraid of chipping the teeth. any suggestions?
If you've already gotten the nuts off, then it will just take some force to pry it off. I had this same concern about mine, just pry it off. Although, I wouldn't recommend putting a prybar on the teeth, you need to get it further under the gear.
Sent from my T-Mobile G1 using Tapatalk
Use a lady slipper pry bar under the edge of the gear on both sides. and hit the end of the gear post with a brass hammer. works for me everytime.
Alright thanks for the prompt responses. I tried a bunch of different pry bars and none of them are thin enough to fit between the case and the gear. I tried prying the case up to force up the gears but no luck. I cant find a pry bar thin enough to fit. Or a gear puller thin enough. Could I special order a tool to do the job?
Thanks in advance.
Thanks in advance.
Use some bp blaster let it sit for some time, i do over night; then hit the round piece around the center it's stuck because it has rust. Then try prying it slightly it'll come off...wasn't born there! In the end if all else fails you'll need to replace the gear..
I got it. I just ground the edges of my puller so they fit underneath the gear and it worked perfectly
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
