98eclipseRS
- 2,850
- 38
- Jan 1, 2003
NORCAL,
California
RU2SLOW? said:Just an idea that just crossed my mind. A local DSMer around here who is pretty highly respected once told me that he would never go with a Turbonetics 50 trim because their turbine setups are much less efficient than comparable Garret ones. He went on to tell me that from his experience for some reason, T-netics turbos never make as much power as their Garret counterparts on DSMs. I entertained his opinion for a while, and I'm still not really sure exactly what to make of it. But completely un-backed opinion or not I thought this personal experience was interesting enough to bring to light in this thread being that the person who started the thread is running an AGP T-netics hybrid turbo. Any thoughts from the turbo gurus around here???
Please tell this well respected guy(why he is I don't know) to sell his dsm do some research and shut the hell up unless he knows what he's talking about. I have the tnetics super 50 and just put down 402 to the wheels on 91 pump. Its all in the tunning.
97gstnick said:ok guys, im gonna try to answering all the questions that i remember reading.
1. yes i did say my car was running good, but that was on 14 psi, car had little pull but i figured i needed more boost to really feel it pull. its at 20-21 and it pulls
3. i am tuning with gm maft. with everything zeroed out my car will cut out at 4500 while in wot due to the fact that it runs so damn rich. and it has only done this since i put on the gm maf. and i have a compensation in my eprom for the injectors. it ran perfect on the t-25 with stock maf.
4. i am running -15% fuel taking away at wot on my maft.
Did you tune again after raising the boost or did you leave it at your 14 psi tune. If you just raised the boost without compensating with a new tune you are most likely pulling timming all over the place when going WOT and that is the start of your problems. Second is you need to do a good tune to realize alot of power. I see it all the time on these boards(this is not meant to bash you by the way just somethign I noticed), some guy throws on a 20g and some supporting mods, turns the boost to 20psi and wonders why his car is slow when he doesn't tune it. Just like old man said it sounds like you have a boost leak issue. Your car is hitting fuel cut not because its running to rich but because your maf is seeing to much air which is caused by a boost leak. And that is causing you to run rich.
Oh and lastly with the gm maf you have to set the first knob(I think its the AUX) to 2 or something to have it set for 450's. having it set to zero across the whole board is if you had 390's in your car a la auto 1g's.
.. I pulled away from a a SRT-4 at 18 psi on a bored out Bt-28... check for boost leaks... do a full boost leak test and check compression. You mentioned about your ignition too... check bad plugs. Post a picture of the plug and it will tell us whats going on inside that engine.... Spark plugs are one of the most important parts of troubleshooting engine issues. They will tell you if you beat them to death, too lean, too rich... ect ect....
) and I have every confidence in the world that my car would stand up to 12 second car on the road.
